Stereo Amp?
Old Feb 24, 2004 | 11:11 PM
Zoltan's Avatar
Stereo Amp?
Anyone have an idea as to where to place a stereo amp in a Screw? I can only think of two places. One being under the rear bench seat or two under the front passenger seat. Both have limited ventilation. Any Ideas?
Old Feb 24, 2004 | 11:34 PM
Dr No's Avatar
The stock amp and sub are under the rear seat but not much room for custom setup.
Mike
Old Feb 24, 2004 | 11:52 PM
Dupuis's Avatar
Read the 3rd post down in this thread. Hope it helps.
https://www.f150online.com/forums/sh...hreadid=146410
Old Feb 25, 2004 | 09:08 AM
Sticker Steve's Avatar
I mounted 1 amp under the passenger seat but did it a little different. Pulled the seat out and lifted up the carpet. Then cut the vent under there back about 10" so you don't notice it being cut but have max room. Sliced the carpet so the vent is still useable. put a screw through the vent into the floor to keep it from moving or rattling. There is excelent ventilation there and works well cause my heater is never much past half way but if it is that cold out, i'd suggest not turning on the floor vents. Amp number 2 is in the dash behind the heater controlls. No problems yet and I play it very loud for hours at a time.
The only problem putting them under the back seat would be then you have no room for the subs!
