04 Screw
Old Feb 15, 2004 | 06:41 PM
cdemot02's Avatar
04 Screw
I need a lift kit for the rear seat. Does anyone know where to find? Has anyone mounted the amps in a 04 Screw, and if so where?
Old Feb 17, 2004 | 03:31 PM
subbox's Avatar
Try LMI Welding
We refer alot of folks to LMI Welding for lift kits (www.lmiwelding.com). I know they have great lift kits for the x-cab trucks. I'll bet they have something for the SuperCrew too.
Andy
www.SUBBOX.net
Old Feb 17, 2004 | 06:49 PM
Dupuis's Avatar
I have an 04 Screw Lariat and I mounted my 4 channel amp that runs my Infinity Kappas in my doors under my pass. seat. I have the heater vents under my seats. What I did was let the back end of the amp sit on top of the vent and I got 2 3'' screws and filed the ends to a point. I than put the screws using nuts through the front 2 holes on the amp holding the front end of the amp 3' about the vent and the floor. The screws stick into the carpet and my amp does not move. I will be mounting my sub amp under the rear seat with my custom box and 2 RE8'' subs. I would not mount my sub amp in the place I put the other amp due to the heat from that vent. A sub amp will get hotter than a 4 channel amp and the heat from the vent combined might be to much for the amp. I have not had any problems with my 4 channel amp with the vent under it. My 4 channel amp will shut down around 180 F. It won't get that hot under there. I have no room under my drivers seat because of the motors for the seat and there is no way to mount an amp behind the rear seat. I will mount my sub amp where the jack is. Hope this helps.
Old Mar 1, 2004 | 11:56 PM
4u2catch's Avatar
cdemot02
If you have the floor shifter, there is plenty of room in the console under the dash
Only speaker wire is run along the door sills to under the rear seats
Slick and out of sight
