2004 F-150 Suppliers
I posted this in another thread, but in case you didn't see it and you're interested, here it is:
List of F-150 suppliers (2004):
PDF File
http://www.autonews.com/files/f150cutaway.pdf
Driver, passenger airbag: TRW Automotive
Wiring harness: Siemens-Yazaki System Technologies
Fuel injectors: Robert Bosch Corp.
Idle air by-pass valve: Denso International America Inc.
Hood liner: CTA Acoustics Inc.
Connecting rod bushings: Federal-Mogul Corp.
Hood: Alcoa Automotive
Wheels: Superior Industries International Inc.
Engine timing chain, viscous fan drive, four-wheel-drive transfer case: BorgWarner Inc.
Integrated air/fuel module: Visteon Corp.
Door panels: Lear Corp.
Floor & Acoustic systems: Lear Corp. Electronic Vapor Management valve: Siemens VDO Automotive
Fornt light bulbs: Osram Sylvania
Cooler and reservoir: Dana Corp.
Hood latch, release: Dura Automotive Systems
Pistons: Federal-Mogul Corp.
Power steering lines: Dana Corp.
Front stabilizer links: TRW Automotive
Tailgate lift assist: Techform Products Ltd.
Starter, alternator: Visteon Corp.
Audiophile sound system: Visteon Corp.
Seat systems, Crew Cab, Super Duty: Lear Corp.
Instrument panels, panel components, electronics: Lear Corp. Inner/outer steering joints: ZF Group NAO
Front lower control arm: TRW Automotive
Seats: Johnson Controls Inc.
Electronic vaccum regulator: Siemens VDO Automotive
Seat belts: TRW Automotive
Window regulators: ArvinMeritor Inc.
Interior auto dimming mirror: Gentex Corp.
Brake fluids: Dow Automotive
Steering rack and pinion gear: Visteon Corp.
Pressure return pump: Visteon Corp.
Front stabilizer bars and front coil springs: Visteon Corp.
Body security module: Siemens VDO Automotive
Overhead system: Johnson Controls Inc.
CD/radio: Delphi Corp. (6-disc)
Power sliding glass rear window: Dura Automotive Systems
Console Shift System: Dura Automotive Systems
Occupant positioning system: Delphi Corp.
Brake components/ABS: Robert Bosch Corp.
Radiator: ..Visteon Corp...
Front and rear axle driveshafts: Visteon Corp.
Instrument panel, console cluster: Visteon Corp.
Front lighting: Visteon Corp.
Windshield: Visteon Corp.
Interior trim, electronics, Crew Cab, Super Duty: Lear Corp. Steering wheel: TRW Automotive
Park assist: Valeo Inc.
Door latches: Intier Automotive
Steering column: Delphi Corp.
Manual seat adjusters: Intier Automotive
Heat shield: Alcoa Automotive
Frame: Dana Corp.
Camshaft bushings: Federal-Mogul Corp.
Front suspension bushing: ZF Group NAO
Passive anti-theft system: Visteon Corp.
Fuel tank, fuel pump: Visteon Corp.
Floor & Acoustic Systems, Crew Cab, Super Duty: Lear Corp.
PDF File
Frame: Dana Corp.
