Vibration
Old Feb 4, 2004 | 02:04 PM
tjaas's Avatar
Registered User
Vibration
Is anyone getting a vibration in the steering wheel at highway speeds.......like the tires need balancing. If so what have you done about it?
Old Feb 4, 2004 | 03:42 PM
jhcir's Avatar
I have done everyting & a Ford field tech has looked at my truck twice and he stated that is the way the truck is. I'm looking at aftermarket stabilizers. Good luck I have heard that from a few people
Old Feb 4, 2004 | 04:14 PM
banjah5's Avatar
I have a slight vibration at 45-50mph but I don't feel it in the steering wheel...it feels like it's coming from the floor of the truck or the heater mechanism...
I did test drive an F-150 that had the steering wheel vibration your referring to though...the wheel vibrated so much that it moved around...Describe your vehicle...5.4L, LSD, build date, etc?
Old Feb 4, 2004 | 06:09 PM
tjaas's Avatar
Registered User
My build date is 6/03 FX4, 5.4, 18" wheels, 3:73 gears, you would think for the price ( MSRP $ 36,000.00 ) it would be smooth as silk, but mybe I expect to much
Old Feb 4, 2004 | 06:17 PM
Dr No's Avatar
tjaas
Try this.
Make : FORD Model : F150 Year : 2004
Service Bulletin Num : 03208 Date of Bulletin: OCT 13, 2003
NHTSA Item Number: 10004891
Component: STEERING
Print and give bulletin number to your dealer.
Mike
Old Feb 4, 2004 | 09:35 PM
tjaas's Avatar
Registered User
Thanks Mike,
Looks like I'm not the only one with this problem, I wonder what they did to fix the trucks made after 8/20/03
Old Feb 4, 2004 | 10:34 PM
WHOZNEXT's Avatar
where do you get that info?
Dr. No,
Where can you get/see that info about service bulletins? Are you aware of any concerning electronic throttle control light / problems? Thanx
Old Feb 5, 2004 | 09:50 AM
Fieldman's Avatar
I had the same problem. The service dept. machined the rotors and now the vibration is gone.
