General tires?
Old Jan 27, 2004 | 02:47 PM
TUFF FORD's Avatar
Re: Re: General tires?
Originally posted by RedR/CFlair
All 4X2 that come from Kansas City plant have Generals ,if they are built in Norfolk they come with Michelins.RW
The 4X2 from Norflolk only? My 4X4 came from Norfolk with the Generals on it.
Old Jan 27, 2004 | 02:50 PM
eastcoastScrew's Avatar
Originally posted by Grimalkin
Thanks for all the replies. My suspicions are confirmed...(1)General tires may be considered a 'lesser' brand (I believe they have something to do with the ride/suspension dynamics that cause the bed shake I've discussed on 2 other threads) and (2) Goodyear Wrangler ATs are great tires...OH, I forgot to mention that the tires I was so pleased with on the '97 were Wrangler ATs. And, yeah, Michelins are great too.
I just made an appointment with Ford service to address two concerns, rear sliding window rattle and deteriorating ride/ suspension rumble at 25-45 over mildly rough road, I also suspect it has something to do with the cheap Generals, I am going to try my best to have them change out the tires....
Anybody have luck with the rear window rattle being fixed at the dealer???
Old Jan 28, 2004 | 01:59 PM
mmckenna's Avatar
4X4 Super Crew XLT built at KC.
17" Generals.
I had General 550TR's on my 94 3/4ton GMC 4x4, they were OK, but not great. Had the chunking issue also. Little bits coming off. Replaced them with BFG's.
I don't think the Generals are the Best, but are not the worst either.
Will definetly replace them with something better when they get thin.
Old Jan 28, 2004 | 02:10 PM
BHibbs's Avatar
My FX4 Screw came with Generals on the 17 inch wheels. I only put a couple hundred miles on them before I upgraded. You can put 285's on the stock rim no problem. That's what I put on mine. I got a 70.00 credit for each tire from Discount tire.
Old Jan 28, 2004 | 02:34 PM
petard's Avatar
285s - does that require getting the speedometer recalibrated?
Old Jan 28, 2004 | 02:40 PM
BHibbs's Avatar
Yes if you want your speedo to be be 100% accurate (if that's possible). I believe my speedo is off maybe 1-2mph at 65mph.
Old Jan 28, 2004 | 08:58 PM
TeckBargins's Avatar
Re: Re: Re: General tires?
I believe my truck is from Norfolk and it came with BF Goodrich tires.
Old Jan 28, 2004 | 09:58 PM
RedR/CFlair's Avatar
Re: Re: Re: Re: General tires?
I dont think 4X4,s come with the same STYLE of tire as the 4X2,s regardless of brand. I was only speaking of 4X2 trucks. RW
Old Jan 29, 2004 | 02:27 AM
Re: Re: Re: Re: Re: General tires?
I hope I am answering this right... My truck is also 4x2
Old Jan 29, 2004 | 10:02 PM
GotTorque?04's Avatar
So most of the trucks with generals are 4x2's??? I should check my vin and see where my 4x4 was made.
Old Jan 29, 2004 | 10:24 PM
BHibbs's Avatar
Mine's a 4x4 with Generals. I think it came from Kansas.
Old Jan 29, 2004 | 10:30 PM
800SwitchBack's Avatar
Question Survey Says
So my flareside fx4 i oredered being built in kansas city is going to come with?
Old Jan 29, 2004 | 10:39 PM
I stayed with the stock 17s
Old Jan 29, 2004 | 11:07 PM
Grimalkin's Avatar
GOODBYE GENERAL...today I traded the wimpy OEM Generals for slightly larger (P265-31.65 inch) Wild Country XTXs. Those of you in the 7-state NW part of the U.S. will recognize the brand (from Schwab Tire Co.). Actually, the tires are made by BFA, a Kelly brand offshoot of Goodyear. I am now enjoying a 50,000+ mile premium tire with a square-shouldered aggressive tread, larger contact patch, rated for severe snow, and quiet, smooth road characteristics. The swap didn't cure the bed shake issue, but I feel more secure and confident (as well as legal in the snow under Oregon law when traction devices are required) with these new tires. GOODBYE GENERAL.
Old Jan 31, 2004 | 09:42 AM
TVFD 22's Avatar
I have General's on my '04 XLT Scab, and I'll spell it out for you:
J-U-N-K!
