Help removing Door Panel
Could someone please post a how-to on taking off the drivers side door panel. Perhaps some of you have done it to install aftermarket component speakers. I can hear something metal rattling in my door something awful and i think that it might be easier to just take the door off myself and investigate.
Any help would be appreciated....I just hate to take off the few screws that I can see and start prying....but that might be what it takes.
Remove the 2 screws at the bottom of the door.
Remove the small plastic cover behind the interior door pull and remove the 2 screws.
The door panels are held on by plastic hook type retainers. You will need to pull up on the door panel to remove it.
Once the door panel is loose, you will need to turn the interior door latch assembly sideways throught the hole to completely remove the door panel.
