Need help ASAP-trim removal
Old Jan 9, 2004 | 05:17 PM
rabid dingo's Avatar
I am changing the stock radio out. I've seen posts to just pull the surrounding trim off starting at the lower right corner. i've tried-pulled pretty hard and it won't budge. Any advice?? Thanks
Old Jan 9, 2004 | 05:23 PM
Wolfman064's Avatar
This is the best I can do - this is an old thread with pictures
https://www.f150online.com/forums/sh...hreadid=133164
Old Jan 9, 2004 | 06:38 PM
lchlucky's Avatar
Rabid I had the same problem. The first time you pull it out its pretty snug.. I finally just pulled real hard and out it came. I have taken off twice since then to reevaluate the room behind it and it came off much easier.
Old Jan 9, 2004 | 06:45 PM
gunner15's Avatar
One thing i did that helped a little was to drop the glove box door all the way down and reach up to the bottom of the center trim panel and push it out as i pulled just above the ashtray it worked a little better than just pulling, didn't have to worry quite so much about breaking it
