Anyone able to get the jack out of their SCrew?
Old Dec 13, 2003 | 11:01 PM
FiredogOH's Avatar
Has anyone been able to get the jack out from under the back seat? I had the rear seat back out and figured out how to take some other things apart but I cannot figure out how to get that damn jack out....nothing in the manual about how to remove it either. I unscrewed it and it won't budge.
Just wanted to get it out of there to make some room under the seat...I figured with the warranty, I would make ford come out and change any flat tire I have. So why should I keep the jack in there?
Old Dec 14, 2003 | 07:49 AM
04xlt's Avatar
I have a SCAB and I took mine out on Friday night. Look closely at the side of the jack that faces the front of the truck. Theres is a clamp that is bolted to the floor that holds the jack. You have to pry it away from the jack and it will come free. Or you can take out the two bolts behind the jack and remove the whole thing. That is a good way to get a close look at how that thing comes out of the clamp.
I was having a liitle trouble myself and was getting a little P@#$ed off. Once I saw how it worked i realized that it was pretty simple.
Old Dec 14, 2003 | 07:55 AM
Jamesdc1's Avatar
Take the screw out.
The jack is "jacked" some to hold it in the bracket.
Unturn the jack screw and it lifts right out.
