Anyone find a rear Lowering Kit yet?
Originally posted by suds5.4
I think Ground Force has shackles out now to lower the rear of your truck about 2". The cost is around $80 or so, and to me, it's a much better alternative that de-arching your stock leafs.
Originally posted by RedR/CFlair
Extended length shackles only raise the rear of the spring which changes the pinion angle of the differential-not a good thing.Because of the increased moment arm, the long shackle will cause some stability problems in a hard cornering situation.Longer shakles would not be my choice. RW
I agree with suds5.4. I think the degree angle with the shackle is one mod that has the least of worries. I've seen 18" lifts and bagged slammed out trucks that last 150K miles and still ticking away.
Plus, I would rather be added or removing components that can be put back (also for warranty reasons) than permanently altering the vehicle.
Just my opinion though.
I don't know if anyone has said this yet but www.truckaddons.com has lowering shackles, 2' by 5' lowering kit, other cool stuff for the 04' F-150.
Originally posted by JTFORD
Forget the shackles and just take the blocks out, you can shim the bolts or buy new shorter bolts. If you want to return to stock put the blocks back in. Its the best move I've made on the truck!! JT Ford
