Audiophile
Old Nov 12, 2003 | 12:20 PM
Fasteddy's Avatar
Audiophile
Anyone know off hand what size the sub woofer is? Just wondering if there was room to modify that box for a 2nd sub or a larger one. Haven't pulled it out yet, want to see if it's even worth while. Thanks in advance
Old Nov 12, 2003 | 03:33 PM
clarkn's Avatar
It has an 8" sub but you may be able to squeek a 10" in the box. I have not taken it apart to be able to tell if you can fit a second sub on it anywhere. Personally, if you would replace the 8 with a 10 you would have all the bump you would ever need. There is something know as overkill...
Clark
It doesn’t matter where you start from, it’s where you finish..
My True Blue Screw FX4
https://www.f150online.com/galleries....cfm?gnum=3236
Old Nov 12, 2003 | 03:47 PM
Fasteddy's Avatar
Yeah, one ten would be fine, possibly 2 eights, no overkill
Old Nov 12, 2003 | 04:04 PM
Clem's Avatar
I'm not an expert by any stretch, but this enclosure may be maxed out with an 8" driver. Most 10"s (or double 8's) require a bit more volume in cubic inches to be effective. It would be a bummer to hog out the opening (or make a second) only to find that the 10" (or 2-8's) in that enclosure just doesn't get it. Then what you've got is a big black paperweight!
