Has anyone looked at and felt their rotors?
Old Oct 29, 2003 | 11:45 AM
wingn8ive's Avatar
I noticed there are "grooves" on mine when I ran my finger across, moreso on the rear passenger rotor than the others, although the "grooves" are slight, they're still present all the way around. I know that "scored" rotors require replacement but don't know if this is the same or if it's normal and will wear in after time.
I haven't noticed any braking issues and everything seems to be functioning properly.... any thoughts?
I planned on taking the truck back to the dealer @ 3k miles (currently have about 1700) for my free oil change... and a few other "little" issues (outside temp., slight pull to the right) and was wondered if I should include this or possibly take it in earlier if this is a problem. Either way, I'm gonna have them look at the brakes and rotors.
Old Oct 29, 2003 | 02:48 PM
Mecheng's Avatar
Grooves are a normal part of the wear process for brake rotors. They will have small grooves from where harder parts of the brake pads wear against the rotor. They shouldn't be a problem. If you haven't noticed a pulsing in the vehicle/brake pedal when you brake normally you should be ok. The only thing "wrong" that could be causing a problem is a caliper sticking. This would result in the pads continously rubbing against the rotor. In this case I woul expect extensive heating and warping of the rotor. This would show up as the pulsing I asked about above.
If the caliper is sticking you should also notice more pad wear on one pad (usually the outer) as compared to the other pad.
Old Oct 29, 2003 | 02:52 PM
wingn8ive's Avatar
cool, thanks ! I was hoping it wasn't a problem... and there's been no pulsing, rubbing or sticking that I've noticed. It seems to brake very smoothly. I'll mention it to the dealer when I take it in for the little things I've mentioned and see what they have to say... it wouldn't hurt to have 'em look at it.
Thanks again.
