Problems?
Problems?
"cliebold" reports on Ford-Truck Enthusists the following...
"Straight skinny here. The Norfolk Plant is on a hold due to a problem with a cracked bolt or something having to do with steering. All deliveries are on hold and those trucks on lots cannot be sold. In Virginia Beach the first delivery was done to a buyer 2 days ago, photos were in the newspaper, and the balance of the trucks that were delivered are on hold. The plant is storing thousands of the trucks in temp parking lots locally. I followed some being driven today from the Norfolk Plant to the staging storage area in Virginia Beach a few miles from the plant. This storage lot was set up in a large vacant area, the groung is covered with a rubber matting system I would guess to keep the tires clean. Convoys were being drove in a shuttles were taking the drivers back to the plant for more. I heard if the lot fills the plant will shut down. The new frames being sent to the plant have been modified to correct the potential problem."
Sure this is an "Urban Legend"
Details - Elaboration - Fix - Exoertise ?
A cracked bolt sounds fixable with the problem being at one work station.
A craked (or crackable/flawed) frame sounds a whole a lot worse and will make me ask questions of the dealer.
Seeking advice from experts, education and general discussion.
Is this serious enough to make one consider cancelling an order?
Seems like Ford is going to have to address this directly, publically and in writing. (MOdified warranty?)
Need input!
Thanks in advance to those with experience and knowledge who can address these issues.
Need input!
Peacemaker
It won't take long. We have only built less than 3000. They have been working on fixing the problem for a week now and they have some workers coming in on the weekends to help fix the problem. My understanding is that the problem is not with the frames, but with a bracket that is welded to the frames. We got these straight from the supplier so it is not a Ford problem per se. There was no way to detect the flaw except from testing. Let's just say that the system worked. The problem was found before they were released to the public.
Thanks for the info 01 and screwbuilder. I thought they had already made a million of them or something. I'm not really in a hurry to get one as soon as they are released. I guess I'm in to big of a hurry to get an "up-close" look at one of these hot mama's. I'll problably buy mine in late 04 or early 05. Anyway, I'm glad the problem was caught ahead of time.
Peacemaker:
I am with you, if I buy one it won't be for a while, maybe an 05 or 06 give some more time needed for a proper shake down and see how Ford treats those that have problems.
If they treat them like those with the door crack issue or the 97 gasket problems, or other things then I most likely won't want to stick my neck out for that...
Thanks Screwbuilder!
This is the kind of factual information which addresses a problem and a solution. These facts make me less worried but ...
FORD ought to be emailing everyone who asked for MORE INFORMATION on their web site. Customer satisfaction depends on informing customers as well as other things.
Obviously they really are not WEB savy yet.
