Limited Slip--FX4 Option?
Old Jul 23, 2003 | 06:16 PM
purty_2004's Avatar
Question Limited Slip--FX4 Option?
Does anybody know if the FX4 comes standard with limited slip rear axle?? On one docment I found on the internet, it shows it as being standard. On the order guide, it shows it as being a $285 option on the FX4.
Anybody know for sure?
Old Jul 23, 2003 | 06:20 PM
purty_2004's Avatar
Also... what is the "Axle Ratio Upgrade"??? It's a $50 option, but I don't know if I need it or not.
Old Jul 23, 2003 | 06:38 PM
wingn8ive's Avatar
From the info I have, if you get the FX4 with 17" tires then 3.55 LS is standard... 3.73 LS is an option (the $285 would come in here). If you get FX4 with 18" tires, 3.73 LS is standard (with no other options indicated). In either case, it appears LS (limited-slip) is standard. Don't know about the axle upgrade option.
Old Jul 23, 2003 | 09:31 PM
purty_2004's Avatar
Thanks, dude! I can now figure $285 less... believe me when I say, "Every penny counts" if I'm going to afford this bad boy!
