Towing Capacity
Old Jul 10, 2003 | 04:42 PM
wingn8ive's Avatar
Towing Capacity
Anyone know how much the towing capacity decreases with 18" tires, as opposed to having 17" tires?
I'm ordering a Lariat, with the towing package (525) and 3.73 limited slip axle, but from all the info I can find, it comes with 18" tires, standard, and doesn't show an option for 17".
It's suppose to be 9500 lbs w/ 17"....
Old Jul 11, 2003 | 08:21 AM
ftlee2003's Avatar
Can anyone answer this question for us? Also, do you think someone will come out with 4.10 gears for the '04 F150 FX4?
Thanks,
Frank T. Lee
Old Jul 12, 2003 | 12:17 PM
geno87_69's Avatar
Any info on this would be greatly appreciated....
Old Aug 15, 2003 | 06:28 PM
CSPinson's Avatar
Some of you probally already know this but, just picked up the new brochure and found the answer. On page 41 under the maximum towing capabilities chart is shows that the Lariat and FX4 w/18" wheels reduce the GCWR and max trailer weight by 500 lbs.
Old Aug 15, 2003 | 06:30 PM
rk2girls's Avatar
i thought you could do the build it on the ford website and get the 4.10 gears in it from the ffactory????
Old Aug 15, 2003 | 06:53 PM
CSPinson's Avatar
The 4.10's are available, but only in the heavy duty payload package , which is only available on regular cabs and super cabs w/ 8' bed. Hopefully someone will offer aftermarket gears though.
Old Aug 15, 2003 | 07:55 PM
rk2girls's Avatar
i wonder if any of these will work......http://www.jegs.com/cgi-bin/ncommerc...=361:confused:
Old Aug 15, 2003 | 07:57 PM
rk2girls's Avatar
http://www.jegs.com/cgi-bin/ncommerc...53&prmenbr=361[/URL] ....this should work a little better..
Old Aug 15, 2003 | 09:03 PM
APT's Avatar
APT
It will proabably be over 8000 pounds. Does it realyl matter? If one plans to regularly tow over 5000 pounds, the benefits of a Superduty will become readily apparent.
Old Aug 15, 2003 | 10:39 PM
CSPinson's Avatar
I'm not sure if Ford will use those rearends on the 04 or not. My 2000 w/ 5.4l uses a 9.75" rear. I'll try to take a look at it tomorrow over in OKC.
Old Aug 15, 2003 | 10:44 PM
CSPinson's Avatar
From what the new brochure says for a supercab 4x4 with the 5.4 and 3.73 rear the max trailer weight would be about 8800lb. Not bad at all for a 1/2 ton. If you haul over 5000 lb almost everyday it probally would be better to have a SD.
Old Aug 17, 2003 | 09:51 AM
543V's Avatar
towing
I HAVE PACKAGED OPIONS SHEETS H .D. PALLOAD (627) INCLUDES LT245X17D BSA A/S. H.D. SHOCKS FRAME AND AXLE SPRINGS AND ALX TRAN AND OIL COOLERS 10.25 AXLE WITH 4.10 GEAR H.D. 72AMP BATTERY THE 10.25 AXLE IS THE SAME ONE THEY USE IN THE S/D 250 AVAILABLE IN REGULAR CAB STYLESIDE 8.0 FOOT BOX (145W.B.) OR SUPERCAB 8 FOOT BOX (163 W.B.)
Old Aug 17, 2003 | 11:49 AM
CSPinson's Avatar
The H D payload pkg trucks ought to be a great machine for towing.
