RPMs fluctuate when letting off gas
Old Jan 23, 2025 | 07:57 PM
1-HIGH-4-BY's Avatar
2001 F150 5.4 4wd. Just last week I’ve noticed if I’m cruising 55-60 mph and I let off the throttle, it feels like you tapped the breaks. When it does this the rpm’s dip down and back up. It started out more intermittent but becoming more frequent. Trans fluid is clean and full. Can a failing IAC cause these symptoms? It starts and idles good
Any thoughts or suggestions would be appreciated.
Old Jan 23, 2025 | 08:53 PM
J_P's Avatar
J_P
Sounds like a fuel-system related issue. Dirty injectors?, low fuel pressure?, Time for a new fuel filter ?
Old Jan 23, 2025 | 09:31 PM
Thanks. I replaced the filter about 40k ago. I’ll grab another one and maybe some seafoam in the fuel.
Old Jan 23, 2025 | 10:38 PM
Could be the torque converter clutch sticking.
*NO* Seafoam - use Techron.
Old Feb 19, 2025 | 06:49 PM
melk81's Avatar
Agree with Techron over Seafoam. Or any product with high concentration of PEA (polyether-amine) such as Gumout Regane, or Redline S1
