Iridium plugs out of fashion?
Old Mar 31, 2023 | 11:05 PM
oldpops's Avatar
Hello all! We have a 2001 F150 Super-crew (5.4L/2V, Automatic transmission, 2 wheel drive) and are looking to get new spark plugs. I remember having them changed many years ago (at around 100,000 miles) and was told they had to be Iridium spark plugs. Is that still the case? I look at the Fordparts.com and they list several Motorcraft plugs for this vehicle, but none say Iridium. Do I need iridium anymore? What's the best plug for this tuck?
Old Mar 31, 2023 | 11:46 PM
The recommended plug is Motorcraft platinum, not iridium. Good for up to 100k.
https://www.rockauto.com/en/moreinfo...t=7212&jsn=463
Old Apr 1, 2023 | 10:37 AM
glc is absolutely correct.
Old Apr 19, 2023 | 05:02 AM
BillSF9c's Avatar
As long as we have the plug, may we plz also get the proper torque and anti-seize (& type) in the thread? TIA glc!
Old Apr 19, 2023 | 10:25 AM
No antiseize, 28 ft/lb on 2 valve engines when Motorcraft plugs are used.
Old Apr 19, 2023 | 10:28 AM
Roadie's Avatar
The Ford manual states spark plug torque at 12 ft lbs. NOT ENOUGH! The current recommendation is 28 ft lbs and not to use anti-seize.
I replaced my original plugs at 119k miles with Motorcraft and I used anti-seize. No plug blowouts. Recently at 171k miles, I started getting misfires, first on number 5 cyl, then number 8, then number 6. It was plugs on number 5 & 6 and coil on 8 I think. Anyhow, I replaced all of the plugs and cops with Denso iridium plugs with Motorcraft cops and still used anti-seize. I left the plug gap at what they came with which was about 0.040". I'll see how it goes. I don't always follow the current recommendations....
My 5.4 idled smoothly without missing at all for the 1st 119,000 miles. After changing the plugs it still idled smoothly for a good while. But the last 10 or 20 thousand miles it had a slight miss at idle. Now, with the new plugs and cops, it idles smoothly again!
