Fuel pressure problem??
Old May 6, 2022 | 05:38 PM
2001SuperCrew4x's Avatar
So I having what I think is a fuel problem. Start up and will drive for a while then after a bit it will pretty much almost stall out. If you hit the gas nothing. Wait a few second and ease into the pedal if will have some power but not much. I checked fuel pressure at the rail. Have 30 psi and 40 when I disconnected the vacuum line. It seems a bit low to me.
oh yeah with truck off for 5 minutes it’s still holding 30psi
Do you think the pump and regulator are ok? Or anything else I check. I’m stumped!!
2001 F150 5.4 Supercew 4x4.
As always. Thanks Marty
Old May 6, 2022 | 05:39 PM
Oh yeah with tray just shut off after running for 5 minutes with pressure gauge attached. Still holding 30 pounds
Old May 6, 2022 | 06:13 PM
I'd replace the fuel filter.
Old May 6, 2022 | 06:20 PM
Crap…so sorry I forgot the mention I did that before the test. I should have before and after
Old May 6, 2022 | 06:28 PM
Roadie's Avatar
That pressure coincides with what mine has read every time I've checked it on my 2002 5.4. Put a couple of bottles of Chevron Techron in the gas.
Old May 6, 2022 | 08:05 PM
projectSHO89's Avatar
If it stalls out while the pressure stays at 30+ psi, fuel delivery isn't the problem.
Old May 8, 2022 | 12:54 AM
J_P's Avatar
J_P
5 Year Member
Do you have any codes ?
Old May 8, 2022 | 01:17 PM
No I do not.
Old May 8, 2022 | 02:35 PM
J_P's Avatar
J_P
5 Year Member
Originally Posted by 2001SuperCrew4x
No I do not.
All of your fuel pressure readings look normal.
It might be an air problem. Check the idle air control valve. Or it could be a sensor problem but those normally throw a code.
Otherwise, you may need to get some better diagnostics. If you don't have the equipment then it may be necessary to pay someone run a diagnostic.
