2000 F150 spark plugs
Old Jul 31, 2021 | 11:35 AM
GB1277's Avatar
I have a 2000 F150 XL with 5.4L. It has 90,000 miles on it. I changed the plugs around 50,000 (15 years ago). I remember that it ran so much smoother after the plug change. It is not throwing any codes, but has a slightly rough idle that feels the same as before the last time I changed the plugs. My main concern is potentially stripping the threads when removing these old plugs. I can't remember how tight I made them since I was still a dumb kid back when I put them in. My concern is any thread damage could present itself after removal. Also possibility of being seized after so much time. Maybe a shot of liquid wrench a few days before I take them out? Maybe I just leave it alone and don't change them? Other than tie rods, nothing has gone wrong with this truck. Just basic maintenance for 22 years.
Old Jul 31, 2021 | 01:41 PM
You won't strip them and they won't be seized. Proper torque is 28 ft/lb. In the very remote chance something does happen, the threads can be repaired without pulling the heads with a Timesert kit. Use only MOTORCRAFT plugs.
Old Jul 31, 2021 | 03:21 PM
GB1277's Avatar
Yea, I will just go for it.
Old Aug 15, 2021 | 08:09 AM
laneman's Avatar
Good advice from GLC. I sprayed throttle body cleaner in the holes and let it soak an hour. Plugs came right out. Also, blow out the holes good before removing the plugs, a lot of crud falls down in there and could go in your engine. Don't use anti-seize on the threads, it will melt and foul your plugs. I torqued mine to 24 and they are holding nicely.
