front AXLE stub bearing
Old Aug 3, 2020 | 10:03 PM
Fbird's Avatar
'02 4x4 280k miles, front left axle stub appears to have a lot of "slop" about .015-.020" vertical movement. Given this is a very SHORT axle and only has 1 bearing (probably a needle bearing) is this something I should check out? I hear a "slap" in the front end on little bumps....and this is the ONLY thing i can find LOOSE.. front end was overhauled about 60k ago.....no other issues but seems this axle stub is "SLOPPY" (to ME)...anybody have "acceptable limits" for runout?
edit...slap i hear is in the suspension somewhere...no doubt about that... But unable to find "acceptable limits" info on axle stub.
Old Aug 4, 2020 | 12:38 PM
Stoned Pony1's Avatar
Are you talking about the plate the axle attaches to on the chunk?
If that is it one of the Mechs working on a mud race truck said your inner bearings are going bad or were not set up correctly. He also said that was to much play. Sounds like a lot to me. There are two bearings and their stuff in there on that side before they hookup to the chunk.
Old Aug 4, 2020 | 06:22 PM
Bluegrass's Avatar
On a 4wd, the front bearing is a >>bolt in<< pack from the back side.
The CV axle protrudes through its spline and held by a large nut on the outside.
Nothing like a 2wd.
Good luck.
