brake controller
Old Nov 30, 2019 | 01:17 AM
jimbo74's Avatar
5 Year Member
brake controller
looking to get a trailer brake controller
from my research, I want a proportional model
not looking for junk, but not made of $ either if that matters
on a Toyota truck site I belong to, one of the guys said the $40 ones were crap..... but I see a lot of $40 controllers from reputable companies, so I don't know.... that is why I am asking.
Old Nov 30, 2019 | 09:46 AM
I prefer the Tekonsha P3. I have one, and it love it. Very intuitive.
I also feel better using it than some of the stock ones in these trucks. The fine tuning that can be done is incredible.
Old Nov 30, 2019 | 11:06 AM
Fbird's Avatar
about $100....gets you a pretty GOOD one.
btw...its all in the mount!!
I added mine about 1 yr ago for our boy scout trailer mounted it in the lil "pocket" in the dash ...lower right of steering column.
Old Nov 30, 2019 | 12:07 PM
JackandJanet's Avatar
I'll second the recommendation for the Tekonsha P3! I had one in my old 2005 King Ranch and it was far superior to the less expensive ones I had in earlier trucks. Don't "cheap out" on the brake controller.
- Jack
Old Nov 30, 2019 | 12:23 PM
Controller and adapter:
https://www.etrailer.com/p-90195.htm...&hhmodel=F-150
https://www.etrailer.com/Accessories...ha/3035-P.html
Do you have the 7 pin wiring and socket installed? If not, you need this:
https://www.etrailer.com/t1-2001_For...Fit-pc-7_Blade
Old Nov 30, 2019 | 12:26 PM
jimbo74's Avatar
5 Year Member
I have a 7 pin and a 4 pin
http://imgur.com/a/mCGKN1A
Old Nov 30, 2019 | 03:07 PM
Good to go with the controller and adapter cable. It plugs in under the dash, near the OBD2 socket.
Old Dec 1, 2019 | 06:28 AM
Fbird's Avatar
Just looked at mine...it's a draw-tite. ^^^^ adapter cable is a bit BULKY so plan a couple of zip ties to tidy it up...plug n play
and a word on 7 blade sockets......
Had to replace mine as it was cracked due to playing in the woods ....ordered a
CURT 55416 Heavy-Duty Replacement OEM USCAR 7-Way RV Blade Socket CURT 55416 Heavy-Duty Replacement OEM USCAR 7-Way RV Blade Socket
This is the wrong one for our trucks (the bolt pattern does NOT line up with the FORD pattern) ...after drilling the bracket to mount it i used it exactly 1 time!!!! soon as i unplugged the traalier 1 of the BLADES came OUT OF THE PLUG IN... after examining the blade ("terminal") it was obvious that it pulled out of the lock tab inside the plastic ......threw it away ...went and bought a new FORD model (IIRC about $75 ..argh) problem solved.
