Jcase fuses for 2003 F150
Old Sep 2, 2019 | 01:00 PM
dstevenson's Avatar
Hi
I want to get some spares for my 2003 F150, 5.4 offroad model. These seem to be called "Jcase" or "J Cartridge" fuses. They seem to be the devil to remove so without doing that, can someone tell me if these 30/40/50 amp fuses located in the box under the hood are low profile or high profile.
Amazon sells these, but I would probably only be able to use half of them.
https://www.amazon.com/Assortment-LOW-HIGH-PROFILE-Nissan-Toyota/dp/B07CS2KYG9/ref=pd_lpo_sbs_263_t_2?_encoding=UTF8&psc=1&refRID=YK1G3RSHKFEXA9QY3JVV https://www.amazon.com/Assortment-LOW-HIGH-PROFILE-Nissan-Toyota/dp/B07CS2KYG9/ref=pd_lpo_sbs_263_t_2?_encoding=UTF8&psc=1&refRID=YK1G3RSHKFEXA9QY3JVV
Thanks in advance.Don
Old Sep 2, 2019 | 10:08 PM
jimbo74's Avatar
5 Year Member
my 2001 uses all long ones
removing them was easy, just pull and wiggle like any fuse. it was actually easier, as they were big. the regular fuses my truck uses are super tiny, I would need a tool
Old Sep 3, 2019 | 08:12 AM
projectSHO89's Avatar
They're "Maxi-" fuses, "JCase" fuses are completely different.
Old Sep 3, 2019 | 09:54 AM
Fbird's Avatar
your fuse panel cover (under the dash) should have a small pr of YELLOW "tweezer" ISH removal
Old Sep 3, 2019 | 04:31 PM
jimbo74's Avatar
5 Year Member
My truck definitely has jcase fuses underhood, and they are the long ones. I can get some pics later
Also uses mini fuses
Old Sep 3, 2019 | 05:02 PM
Yeah, Google lead me wrong when I made my image search for the "J cartridge" and it returned cylindrical fuses as one of the possibilities. If you limit calling them "Jcase" then you get the right ones as that is the correct name for them.
Old Sep 3, 2019 | 07:33 PM
jimbo74's Avatar
5 Year Member
No worries. I had never heard of them before. I had to google it. Then went out and checked my truck
