Working on PATS system
9356 is actually a common code that shows up in the Ford focus as ignition open but in the f150, it just means it's on. When I hope the OBD2 up it shows no codes. I'm thinking there is an issue with the crankshaft sensor. Only avenue I haven't yet explored that would cause no spark symptom's. Either cause I wired it won't when I did the new harness or it's just plain bad and needs to be replaced.
