Pats Issue and quick Question
Old Feb 15, 2022 | 12:56 PM
Red Gator's Avatar
Exclamation Pats Issue and quick Question
2003 f150 supercrew v8 4.6l. After battling with a stupid code for evap circuit A code and being told the driver in pcm was bad I replaced pcm. Well purchased new keys and locksmith says he was unable to program them due to unklnown electrical issue. My expensive mechanic said to put the old pcm in and drive it to him for a diagnosis. After doing so the truck is in theft mode and cranks with non start. The usual. The theft light blinks code 12. My scanner says the only codes are b1428, b1213, and p1260. My question is should I just have another locksmnith reprogram the old key and a new key to the old pcm? Or will it be a waste of money and not work as the other locksmith said? I need to get truck running again as it is my livelihood and how I feed my children like the rest of us. Please lend some knowledge and expertise but most importantly ADVICE! Thanks so much
Old Feb 16, 2022 | 06:51 PM
Veteran: Army
for starters stop making modifications without researching
have the truck towed to the nearest dealer who can program the ecm and pats
it won’t be cheap but the fastest way at this point
