1997 f-150 headlight issues
I have a 97 f-150 with no High beams. tested all fuses and relays with a meter, all good. FTP stays on low beams when pulled back. When lever is pushed forward I loose L and H beams. Pulled MFS and tested. Have power to H and L when in the correct positions. When in H the switch cuts power to the L beams but retains power to the H beams but not to the lights. Also the dash indicator doesn't work. Not sure if it's a ground issue or in the MFS itself. Any help would be appreciated.
