Thanks for the add! New member with a question!!
Old Jan 15, 2019 | 08:13 PM
Inkster's Avatar
2001 F150 4.6 bad motor typical blown spark plug hole! Question is what other motors bolt to the bell housing?
Old Jan 15, 2019 | 09:12 PM
Roadie's Avatar
If a blown plug is the only thing wrong with your engine, it can be easily repaired.
Old Jan 15, 2019 | 09:20 PM
Inkster's Avatar
Well I also had manifold issues so motor was pulled timing chain cover was leaking! Long story short the guy that pulled the motor doesnt want anything to do with it now so I'm looking into making it a mud toy!
Old Jan 15, 2019 | 11:34 PM
Any of the following will bolt up, but with varying degrees of swap issues and difficulties. Forget the diesels.
Modular V8 pattern
  • 4.6L SOHC/DOHC V8 (later castings, F3VE and up)
  • 5.0L Coyote DOHC V8
  • 5.4L SOHC/DOHC V8
  • 6.0L Navistar Power Stroke DI turbodiesel V8 [5R110 Automatic Only]
  • 6.2L Boss SOHC V8
  • 6.4L Navistar Power Stroke DI twin-turbo diesel V8 [5R110 Automatic Only]
  • 6.7L "Scorpion" Ford Power Stroke DI turbo diesel V8
  • 6.8L Triton SOHC V10
Old Jan 16, 2019 | 06:04 PM
Where are you located? Interested in a clean drop out 4.6 engine/trans with 102k miles?
Old Jan 19, 2019 | 11:38 AM
Veteran: Army
might be time to learn how to install spark plugs or get a bus pass
