funky smell with fan on
  #46
Old 09-16-2018, 04:15 PM
glc is offline
Can't go wrong with OEM or Fel-Pro unless you install a Dorman manifold, then you have to use the Dorman gaskets.
  #47
Old 09-17-2018, 09:33 AM
jimbo74's Avatar
I never did find out why my motor was leaking before tearing it apart..... hopefully, it isn't that crossover at the front, otherwise I will be tearing it apart soon after this repair.....
you have personally used felpro? I am old school, and I know with old toyotas that Felpro head gaskets are no go.... but I guess that is kinda apples to oranges here....
  #48
Old 09-17-2018, 07:40 PM
ErikShockey's Avatar
The 1999 (P.I.) 5.4 F150's came with an aluminium intake manifold. That is the only direct swap that I know of.
Fel-Pro gaskets are good quality. Usually the best you will find at a parts store.
  #49
Old 09-17-2018, 07:55 PM
glc is offline
Those 1999 aluminum manifolds are getting very hard to find.
  #50
Old 09-21-2018, 07:01 AM
jimbo74's Avatar
ok so I have been looking @ the felpro gaskets, it seems there are 2 different types? one is the regular and one is perma dry? I a, seeing tons of different part numbers as well
this also got me thinking, could it be the junction where aluminium crossover pipe mates to the plastic intake? could this be where my leak was from?
I never did find out where it was from.....
does a new gasket set have the provisions for the crossover to intake path, or is that another gasket set?
  #51
Old 09-21-2018, 11:13 PM
https://www.rockauto.com/en/catalog/...ket+/+set,5424
The Fel-Pro PermaDry gaskets are an improved design over factory but not totally necessary. The set comes with intake, throttle body and thermostat.
https://www.rockauto.com/en/catalog/...ting+set,10261
^Those are for the coolant crossover. Those usually don't fail but I have seen the plastic around the crossover crack and leak. I've also seen post from people that cracked the intake trying to remove the coolant crossover.
  #52
Old 09-22-2018, 09:23 AM
jimbo74's Avatar
Just ordered the:
FEL-PRO MS98008T3
FEL-PRO ES71213
Hope it isn't my manifold that is leaking... if it is, at least I will know how to do it when I pull it again
I will be doing the coolant pipe mod/fix when I get this intake off as well
  #53
Old 10-07-2018, 07:47 AM
jimbo74's Avatar
going to try and pull the manifold tomorrow
  #54
Old 11-22-2018, 07:24 AM
jimbo74's Avatar
so, still don't have this done yet..... and I am not 100% sure that the pipe is my leak, but I hope it is
if not, I know how to do this again if need be GRRRRRRRRRRR
I have the manifold almost off, just need to pop the fuel rail clips, and then remove the bolts to the manifold itself. everything else is off and good to go
I have read all the threads I can find pertaining to this, what is the correct way I should look to replace it? run a regular hose all the way from just behind the water pump, or do a small section?
  #55
Old 11-24-2018, 12:00 AM
I've done this repair on three trucks now and on two of them the source of the leak was the connection behind the water pump.
On those two trucks I only cut the last few inches off the pipe and replaced that small section with hose.
The third truck had a pin hole leak in the pipe itself so I replaced the entire pipe with hose.
  #56
Old 11-27-2018, 07:26 AM
jimbo74's Avatar
Originally Posted by jimbo74
erik, what do you think of this way? I do plan to take my whole intake off though to get in there and clean it all up
(I am no joke about 5 minutes from having the intake off, and a real 5 minutes, not the 5 minutes we all tell our wives it is going to take and takes 3 weeks )
  #57
Old 11-27-2018, 09:14 AM
jimbo74's Avatar
deleted
  #58
Old 11-27-2018, 01:39 PM
jimbo74's Avatar
GOT THE MANIFOLD OFF!!!!!!!!
now the fun begins, this thing is gross
also, there is a wire connector @ the back, whatever it is goes into the middle of the valley, but the wires insulation is pretty trashed.. so will need to address that......
ok, so why was my junk leaking?!
that pipe looks pretty dry really, but that valley is nasty and full of liquid.... in the front it appears to be full of oil.... EEK?!
sorry these pics are huge!
  #59
Old 11-27-2018, 02:27 PM
glc is offline
I think that wire is for the knock sensor.
  #60
Old 11-27-2018, 09:04 PM
That is the knock sensor wiring.
The pipe itself isn't what leaks or gets wet, its the connection of the pipe to the water pump that leaks. It's hard to tell from pictures if that is where your leak is coming from but it looks pretty gunked up at the water pump connection.
You can replace the pipe with hose like in the video you linked, I've never done it that way but it should be fine.
If that is not the source of the leak it could also be an intake gasket leak or the actual intake leaking.
Quick Reply: funky smell with fan on
