Vandalized ‘01
Old Feb 10, 2018 | 01:09 AM
Mr.Nasty's Avatar
Vandalized ‘01
Hi guys. I bought an ‘01 XLT Supercrew that someone tried to steal from the previous owner. So I put a new steering column and ignition in, got the key programmed, and took graffiti off of the paint.
But after looking around I saw the fuses were taken out. Not all, but a few. I can’t find a picture online on what fuses go where.
Would anyone one happen to have a pic of the fuses underneath the dash?
Please and thanks!
Eric
Old Feb 10, 2018 | 07:04 AM
enriched's Avatar
Please and thanks!
Eric
Did you get a a owners manual with the truck? should be in there. Also is the fuse panel cover still there? the might be a fuse map on the inside of it as well
Old Feb 10, 2018 | 09:45 AM
https://www.fleet.ford.com/partsands...owner-manuals/
Old Feb 10, 2018 | 09:49 AM
Mr.Nasty's Avatar
There wasn’t a manual and there isn’t a map on the cover. 🤬
Old Feb 10, 2018 | 09:52 AM
If you click on the link I gave earlier, I bet there is a manual in there.
Old Feb 10, 2018 | 09:58 AM
Mr.Nasty's Avatar
lifesaver! Thank you!
Old Feb 10, 2018 | 10:04 AM
No problem. Glad we could help!!
Old Feb 11, 2018 | 04:37 PM
Mr.Nasty's Avatar
Well, the AC Delay Relay 30 amp fuse was missing under the hood and I put one in thinking that would solve it.
It it didn’t and I still don’t have any air flow coming from the vents. I can hear the gears moving when I switch from defrost, panels, floor etc but no air.
What at can be wrong?
Old Feb 11, 2018 | 07:24 PM
Might be the blower motor or resistor is toast.
Old Feb 12, 2018 | 06:43 AM
enriched's Avatar
Might be that the blend door is broken, (fairly common)? Or are you not getting any air at all to come out in any location inside the cab? If that is the case, Then back to the blower motor.
