Spongy Brake Diagnostic
Old Jan 18, 2018 | 03:54 PM
finallyfarm's Avatar
When I click the mountain icon I get a request for image URL? Do I need to upload pics to somewhere?
Old Jan 18, 2018 | 04:14 PM
I think the pics are now attached.
Attached Thumbnails Spongy Brake Diagnostic-dsc01139.jpg   Spongy Brake Diagnostic-dsc01140.jpg   Spongy Brake Diagnostic-dsc01141.jpg   Spongy Brake Diagnostic-dsc01142.jpg
Old Jan 18, 2018 | 05:40 PM
If you scroll down, you will see the option to browse device.
Old Jan 19, 2018 | 02:04 PM
I believe the pics of right side finished are available. Let me know if not. Meanwhile, I opened up left side rear. Shoes on that side appear as new and I don't see any difference in how that is installed. Any inspirations on next step would be appreciated.
Old Jan 26, 2018 | 05:50 PM
Continuing to look for a problem: I removed all installed parts of right side and then carefully reinstalled. Hub goes on with a little difficulty and manual rotation shows resistance but I can turn it.
Possibilities?:
1. Wheel cylinder. Top of both shoes are in contact with anchor post so I assume that means cylinders are completely withdrawn and not the issue.
2. Wrong new shoes. I compared with old. Metal is same dimensions, no shoe material left so can't tell. They seem same as left.
Old Jan 26, 2018 | 09:11 PM
Roadie's Avatar
If brake shoes aren't adjusted properly, the brakes will be mushy and work very poorly. The shoes should be almost in contact with the drum.
Old Jan 27, 2018 | 08:50 AM
The problem I seem to be having is that I cannot adjust the brakes away from drum. Adjuster is completely screwed in (as short as possible) and yet shoes are still in contact with drum. Upper half circle of shoes is in contact with anchor and bottom end is constrained by adjust screw. The only explanations I can think of is either wrong shoes or I just need to let shoes work in.
Old Jan 27, 2018 | 09:31 AM
I have found no way to adjust the shoes away from the drum.
Old Jan 27, 2018 | 10:10 AM
Roadie's Avatar
Maybe take it to a brake shop.
Old Jan 27, 2018 | 01:12 PM
My conclusion as well. Thx for trying. I'll try to let you folks know what it was.
