Air bag dash lite
Old Jan 25, 2017 | 12:20 PM
kitchenguy's Avatar
Air bag dash lite
Since owning this 1999 F-150 4.6 XLT, the amber air bag dash lite has always flashed, indicating a fault in the system. My question is other than a defective wheel clock, could a alternative cause bee that this truck came to me with a master cylinder that was incorrectly replaced with one which doesn't have the port that should have the electrical connection for its' corresponding mating plug which of course is not connected at this time?
Old Jan 26, 2017 | 12:28 PM
mkosu04's Avatar
The air bag light???
or do you mean the brake light?
The MC would not have any relation to the air bags.
If you do mean the air bag light - then check the pattern for the flashes. I know for the 2004+ years at least the light flashes in a specific pattern that will tell you what is wrong.
Old Jan 26, 2017 | 11:13 PM
kitchenguy's Avatar
Thanks for the reply, although I am aware of the air bag lite flash code. Was interested to learn if the missing electrical connection at the master cylinder could in any way cause or contribute to the problem.
Old Jan 31, 2017 | 06:25 AM
Parnelly's Avatar
Low impact sensor tripped?
Old Jan 31, 2017 | 02:41 PM
Thread moved to 97-03 section
You need to put an SRS capable scanner on it and read the codes
