new here
Old May 17, 2016 | 05:21 PM
rick4wd's Avatar
new here
I have a 2000 f150 excab 4x4 with 94k and have a couple things to ask. its my first ford
sometimes when I turn while applying brakes I get a sqeal but only when I turn. and it has extra springs in rear but no badge for 7700 thanks for any help
Old May 19, 2016 | 07:02 AM
enriched's Avatar
Do you have 5 lug nuts or 7? it maybe that prior owner added a extra leafs ?
On the brakes, Does it matter which direction you're turning to get the noise? does it wander abit going straight down the road?
It can be many things...could be brake pads and or rotor are warn. or tie rod are bad or wheel bearings.
Old May 19, 2016 | 06:51 PM
rick4wd's Avatar
yes only does it when I turn right and goes straight down the road 5 lug
Old May 19, 2016 | 08:24 PM
Roadie's Avatar
Depending on exactly how it squeals, I might suspect the power steering pump.
Could be the brakes, ball joint, or bearing hub? Tire rubbing if you have oversize tires?
Old May 19, 2016 | 11:36 PM
With 5 lug, you do not have a 7700.
Old May 20, 2016 | 09:35 AM
rick4wd's Avatar
thanks for the help like the help like truck so far
Old May 21, 2016 | 08:03 PM
enriched's Avatar
like glc pointed out that with only the 5 lug nut pattern it is not the 7700 so some one must of added the extra leaf/ over load pack.
as for the noise when turning to the right... well you need to check out the brakes and the wheel bearings, least off that would be my first suspects anyway. I'd start on the left side, but it certainly could be either side. If that checks, then I'd move to the tie rod ends and lower ball joints
