starting the truck
Old Mar 21, 2016 | 04:14 PM
jahmen's Avatar
starting the truck
Howzit,
about 3 months ago I purchased a 2003 Ford F159 from an auction for $125.00. The only thing I had to do on it was to change the steering column and figure out how to get the truck started. Since I could jump start it from the starter Relay(Solenoid) That ruled out the Fuel pump, Starter and being a bought a new Starter relay(Solenoid) the process of elimination has begun, Changed out the DTR(Neutral safety switch) and the ignition switch, Still no crank no start. So I traced a little wire that had no voltage which was attached to the solenoid. It went into the fusebox and into the cabin, and that's when I noticed that it had been cut and capped off. then I noticed the same colr wire coming out of the ignition switch going into this little black box which was beeping. Come to find out after researching this box, It is a device called a PTE-2 Passtime. It's like a box that disables your Vehicle so it doesn't start. Supposedly if you don't make payments on your truck it shuts off the truck, That sucks after all the work I out into it. Does anyone know how to disable this thing or being that I got this from an auction would I need to take it to the dealership well cant take it cause it don't start. Any advice would be appreciated
Old Mar 21, 2016 | 04:51 PM
projectSHO89's Avatar
Bypass it and restore the wiring to original or just unplug it and jumper the purple and blue wires.
Some previous owner probably had bought it from a tote-the-note car lot and the sleazebags installed that hoping they'd get paid on time. It's just a starter interrupt.
Old Mar 21, 2016 | 05:05 PM
jahmen's Avatar
@ projectSHO89
Thanks for the reply. I apologize for not being Electrical savoy but when you mean by Jumper the purple and blue wires, Do I cut those out from the PTE-2 and splice it back and oh I get it now, Thanks I'll do that when I get home.
