Upgraded 4R70W transmission cooler
Old Feb 19, 2016 | 02:31 PM
maxh64's Avatar
Hey Guys, so i bought an upgraded transmission cooler, and a derale remote filter kit. I am having some trouble figuring out how to set this up. I was wondering if anyone else on here has done this to their truck and how they ran the set up. I know you cut the transmission lines where they come up for the auxiliary transmission cooler, and flare the ends ( dont have a flaring tool )
I just wanted to see if anyone else has done this, and if so, how? thanks
Heres the cooler:
Amazon.com: Hayden Automotive 405 Ultra-Cool Tube and Fin Transmission Cooler: Automotive Amazon.com: Hayden Automotive 405 Ultra-Cool Tube and Fin Transmission Cooler: Automotive
Old Feb 19, 2016 | 06:15 PM
AndersonS's Avatar
A stacked plate cooler is better than a tube and fin, but these should help.
https://www.f150online.com/forums/ar...how-loads.html
http://www.timskelton.com/lightning/...er_install.htm
Old Feb 19, 2016 | 06:46 PM
maxh64's Avatar
Yea I know, Im not doing anything heavy duty, just wanted to upgrade my Auxiliary cooler to a better one and will be doing some light towing soon. So this will help. But thanks these links help!
Old Feb 19, 2016 | 08:15 PM
Roadie's Avatar
So, are you saying that your truck already has the trans cooler mounted in front of the radiator/condenser? If you do, you don't need a larger one for light towing. If your truck only has the trans cooler inside the radiator, yes you need an additional cooler in series with the cooler inside the radiator.
