5.4 4v swap?
Old Feb 4, 2016 | 07:03 PM
Michael Mciver's Avatar
5.4 4v swap?
I just searched and found nothing has anyone done a 4v swap into a 97-03 f150 none Blackwood of course. I can either get one out of a navi or Blackwood, and if someone has done it have they had wiring issues, will the engine harness bolt up and not need pin moving to use the factory Pcm that's already there
Old Feb 4, 2016 | 10:02 PM
People have done it. I don't know much about the swap itself.
In general I'd use as much as possible off the donor vehicle.
Old Feb 6, 2016 | 12:06 PM
well yea im gonna use the harness off the donor engine all that but just didnt know if i could plug that harness into the bulk connector on my truck and be done, the firing order is the same so i shouldnt need the pcm from donor vehicle
Old Apr 18, 2016 | 10:05 PM
IntRiniTy's Avatar
4v swap
I would think if your keeping the pcm, you would keep the same wiring harness. There's no reason your pcm/sensors wouldn't run the 4v. Same injectors? Prolly would at least need COP adapters.
Really the block on all 4.6/5.4 2/3/4 valve are essentially the same. Given the 5.4 are a lil wider and higher because of the longer stroke.same bore.The timing cover and heads vary.
Your best bet is to read mustang forums and go from there. I wanted to do a 4v but would have a problem bolting my 4.6 2v fly-by-wire TB to the 4V 5.4 intake manifold. I ended up buying mustang adapter plates and bolting in the 2v 5.4 short block. It's the only 2v 5.4 fly by wire truck in existence.
Good luck on your build! Keep us posted!
Old Apr 19, 2016 | 12:40 PM
IntRiniTy's Avatar
http://www.stangnet.com/mustang-forums/threads/5-4l-dohc-swap.879938/
Gives you an idea
Old May 6, 2016 | 08:04 AM
JMC's Avatar
JMC
25 Year Member
Your 97 has coil packs so use them. Personally I would use the 97 PCM and wire harness. This will eliminate chasing gremlins in the wiring. The last thing you want to be doing is checking that the 4v wiring is compatible with the 97.
Old May 6, 2016 | 10:49 AM
Profile says he has a 03, which is COP, not coil pack, unless it's a V6.
Old May 6, 2016 | 02:19 PM
JMC's Avatar
JMC
25 Year Member
glc, glad you pointed that out. There will be issues with the intake manifold runner valve. The F-150 doesn't have one. This valve opens up to change the path of the incoming air in the intake manifold.
Old May 6, 2016 | 05:55 PM
The V6 has a IMRC, the 4.6/5.4 2v doesn't. Are you saying the 4v has one?
Old May 7, 2016 | 03:36 AM
JMC's Avatar
JMC
25 Year Member
I am sure the 4.6 DOHC has them but now you have created doubt about the 5.4 DOHC. I will check and get back.
Old May 16, 2016 | 09:32 AM
I have a 03 supercrew 5.4 2v im a tech at a ford dealer and have access to wiring diagrams there was few different pin loactions for grounds one power and different for tranny, that was based off of a 02 navi I haven't checked the blackwoods to see what tranny they have and what not, finding a blackwood would be a lot harder than a navi lol
Old May 16, 2016 | 10:23 AM
I'm pretty sure the Navi and Blackwood 4 valves used the 4R100. You most likely have a 4R70W in your 03 truck.
Old May 16, 2016 | 11:45 AM
that's correct just realized that the tranny harness and engine harness are separate so ill just get a engine harness for a 4v and If I need to swap pins for whatever I will and it will be a clean install
Old May 16, 2016 | 12:45 PM
Are you going to keep the 4R70W or are you also going to swap a 4R100 in?
Old May 16, 2016 | 02:55 PM
well im about to build the 4r70w so ill keep my 1 2 shift is super sloppy even with shift pressure turned up on the programmer so im doing upgraded towing convertor, stage 2 clutches and a shift kit so the 4v build will wait till next year hopefully or just do a fully built 2v
