Cb Set up???
Old Apr 2, 2015 | 11:39 PM
Cowboy_Ben's Avatar
Cb Set up???
I've got a CB already installed in my truck but i wanted to see how other people mounted theirs and how they mounted the antenna.
Old Apr 2, 2015 | 11:41 PM
Cowboy_Ben's Avatar
How ive got my antennas mounted. I mounted my Cobra 19 ultra iii from my overhead console. ill try and post a picture later.
Old Apr 3, 2015 | 05:52 PM
Cowboy_Ben's Avatar
My CB location
Old Apr 3, 2015 | 08:08 PM
Red13's Avatar
What are you using for a power feed?
Old Apr 3, 2015 | 08:29 PM
Cowboy_Ben's Avatar
I ran the wires from the cb trough the headliner down the a pillar under the dash to a noise filter than I ran them to the fuse box under the hood using a push on connector
Old Apr 3, 2015 | 11:31 PM
Bluegrass's Avatar
I am a licensed Amateur Radio op and run Ham radio in my 02.
I built a custom mount from 1" square tubing.
It is in a TEE form bolted to the stationary seat frame brackets.
Comes up at a sleight forward angle then vertical.
There are 2 adjustable side bars that provide mount for 2 different radios just above seat level.
The compound angles are adjusted to face the radios to the driver.
The installation is made to clear the seat movement forward and back and still clear all dash dial control functions and even the cup holder access is free to work without interference..
Separate power comes through the fire wall from a 30 amp fused battery source to an alternator filter with a connector strip to hook radio supplies to.
My power levels are in the 100 watt class.
The DC feed has to be #10 wire from the battery to an alternator filter because up to 20 amps is drawn on voice peaks in Single Side Band mode.
2 meter antenna is mag mount.
HF radio antenna is mounted on the trailer hitch draw bar, is tilt-over and quick removal with slide lock pins for tail gate drop access and can even tow trailer with antenna in place.
I know without photos it's hard to visualize but that's the way I do it and proven to be hardy.
When this truck is no longer owned, all the hardware is removable without
obvious signs or installation holes and markup.
Good luck.
