Cruise control disengageing
Old Sep 22, 2015 | 03:36 PM
SWITZERSLAND's Avatar
ok, That maybe it. I'll get one from FORD.
Old Sep 22, 2015 | 09:21 PM
FordMasterTech's Avatar
They should have them on the shelf. 1L1Z-9F924-AA if memory is correct
Old Sep 22, 2015 | 10:14 PM
Cc is working again. Thanks Guys
Old Sep 22, 2015 | 10:35 PM
Bluegrass's Avatar
New part $30.
Advice $300.
Put check in mail.
Good luck.
Old Sep 22, 2015 | 10:55 PM
Originally Posted by Bluegrass
New part $30.
Advice $300.
Put check in mail.
Good luck.
Thank you,
Keep my tab open, this baby is running strong at 184980.
Old Sep 23, 2015 | 12:44 PM
So it was the switch? And a Motorcraft one fixed it?
Old Sep 23, 2015 | 04:14 PM
Correct. The (secondary) switch on the master cylinder. An advance auto switch worked for two weeks the failed to hold speed.
Old Nov 24, 2015 | 10:14 AM
Well that didn't last very Long. That's what she said about this Cruise control fix. It stopped working again. So Motor craft switch is 30 days better than Advance ? What could it be ?
Old Nov 24, 2015 | 10:56 AM
grizzstang's Avatar
Maybe you just got a bad switch from Ford, mine has been in for several years now with no issues.
Old Nov 24, 2015 | 05:11 PM
Old Nov 24, 2015 | 09:19 PM
Bluegrass's Avatar
I will bet the master cylinder pressure switch is being opened due to rising pressure for some reason.
If you put a shunt connection across the switch plug and CC holds over an extended time period , it should prove the cause.
If that should be the case, the master cylinder may need to be replaced.
The master cylinder switch is a special design originally developed by Texas Instruments company, years ago.
It has to be sensitive to low pressure to open the contacts and and standup under very high pressures when brakes are applied normally, that ranges in the hundreds of pounds pressure.
As we find, not every company pays attention to the production quality and specs for the switch application they put out for vendor sale.
Good luck.
Old Nov 30, 2015 | 01:18 PM
Snow on the grownd. Now CC is working again. Inop when the outside temp warms up to 60's. I'll try the shunt, BG.
Old Jan 4, 2016 | 12:15 AM
Thanks Bluegrass for all of your help. (happy new year) It's working more than not. The Good news is Santa somehow stuffed a 2012 F-150 Raptor down the Chimney. So My 99 F-150 Lariat 4X4 is (Tear in Eye) going on a page of thrifty Nickel. Good Luck and again thanks.
Old Jan 10, 2017 | 04:24 PM
Yagman's Avatar
I have this problem but it only disengages when it's cold outside (40 degrees or less). Seems to be interior heat related but I am not sure. I have not checked anything out yet. It cuts off and I cannot resume or set. Wait a while and then it will come on, sometimes for an instant, sometimes for a few minutes. Turning it off via the on/off switch seems to make it start working again sooner. It's usually out for 3-5 min. I've tried turning the heat off, which worked for a while, but does not work always now. Any thoughts appreciated.
Old Jan 10, 2017 | 06:27 PM
projectSHO89's Avatar
See post #26.
