I bought a plug spitter
Old Oct 29, 2014 | 08:38 PM
  #31
jethat's Avatar
how many miles? If it has lots I'd just find a better motor/ If it only has around 100k or less I'd fix it. Try to anyway..
Old Oct 29, 2014 | 09:56 PM
  #32
Originally Posted by jbrew
Patrick, you going to have to explain that one in the near future, - I'll hold you to it lol. I'd love to finish the truck off with a 3V V10. If you could pull that off, I'd shine your shoes for week!
If you were to have a full donor vehicle that runs and drives. In theory you'd have everything you need to put it in another vehicle. Nothing more than engine/trans swap and merge the body harness into the donor engine harness
Old Oct 29, 2014 | 09:59 PM
  #33
Before you pull the head, try a borescope. You should be able to "rent" one of those too.
Old Oct 30, 2014 | 08:33 AM
  #34
ishootstuff's Avatar
Originally Posted by jethat
I bet you have a chiped valve. Pull the head and check it out. Probably just need a valve.
That would not explain the excessive oil on the plug though.
Old Oct 30, 2014 | 09:16 AM
  #35
It could have torn the valve seal prior to going in the combustion chamber
Old Oct 30, 2014 | 09:31 AM
  #36
Huh? How would a chunk of stuff from a spark plug hole get to the valve seal? I have not paid much attention to the valvetrain on these modulars, but the valve seals slide on top of the valve and live inside the spring coils, yes?
Old Oct 30, 2014 | 03:45 PM
  #37
jethat's Avatar
If the chip went past the valve it could damage the seal I'm thinking is the logic there..So valve gets chipped and it happens I've seen it and the broken piece shoots up behind the valve.. if the engine is otherwise good might be worth a look. Probably scrap pretty much though.
Old Oct 30, 2014 | 05:29 PM
  #38
OK, maybe my brain isn't working, but how is something going to get from the combustion chamber PAST THE VALVE GUIDE and under the rocker cover to get to a valve seal?
Old Oct 30, 2014 | 06:08 PM
  #39
Exhaust sidr, air goes past valve and out of the manifold. Right there is where the seal is no?
Old Oct 30, 2014 | 06:41 PM
  #40
No. The red circles are where the valve seals are - again, unless I'm just not understanding what you guys are saying.
Old Oct 30, 2014 | 07:34 PM
  #41
jethat's Avatar
probably what happen is the chunk of chit bounced around in the cylinder for awhile damaging the cylinder wall. Wont know for sure till you take off the head. Could be the valve stem got bent..
Old Oct 30, 2014 | 08:13 PM
  #42
I hate to be a pest - but you really need to borescope it before ripping anything apart.
Old Oct 30, 2014 | 08:39 PM
  #43
I have one, but the head is too big to get in the plug hole. I was just thinking today that it's time to upgrade that sucka.
EDIT: Just bought one. I'll post pics sometime next week.
Old Nov 3, 2014 | 10:53 AM
  #44
I'm going to try to get a better video. This is my first try using this thing. It has a mirror attachment I need to test out. I have to admit, I did not expect to see what I saw in that cylinder. Looks to me like coolant is in there. You can also see where the helicoil impacted the piston at about 2:30.
Old Nov 3, 2014 | 11:01 AM
  #45
Nothing I saw was super obnoxious other than the oil/coolant mix. But hey at least you know the rings are good
