Shelby GT500 Engine on 97 F150
Old Nov 21, 2014 | 09:10 PM
  #76
FordGuy24's Avatar
Great work!
Old Dec 1, 2014 | 12:38 PM
  #77
the_tool_man's Avatar
Originally Posted by Casey05
Looks awesome. Glad you stuck with it, and didn't leave it in project limbo!
Yes. ^^This.^^ So many of these projects die at the 90% point.
Old Dec 17, 2014 | 02:52 AM
  #78
F150_UAE's Avatar
Here it is.. The start up officially with no exhaust leaks and nothing but Tuning and Driveshaft safety loops.
http://vid19.photobucket.com/albums/...216_193847.mp4
Stay tuned for a go pro video of a burnout
Old Dec 17, 2014 | 10:35 AM
  #79
Blue-02-2wd's Avatar
all I can say is nicely done. Install looks clean and sounds impressive! Good Job
Old Dec 17, 2014 | 01:42 PM
  #80
I WILL stay tuned for the burnout video!
You've officially got the ultimate sleeper.
Old Dec 17, 2014 | 08:25 PM
  #81
Almost there!
Old Dec 17, 2014 | 08:45 PM
  #82
FordGuy24's Avatar
That's sweet
Old Dec 17, 2014 | 11:14 PM
  #83
F150redneck's Avatar
We want burnouts!!!!!
Old Dec 21, 2014 | 03:26 AM
  #84
F150_UAE's Avatar
Yes I promised for a burnout vid, had 2 issues,
1) Driveshaft : Needed a few tweeks @ the machine shop (SOLVED )
2) Slave cylinder : The stock Slave cylinder wasn't holding up good since its very old, in the process of looking for a replacement and should be done ASAP.
I need to blow out the tires guys.. trust me I will have no mercy on those rubbers
Old Dec 22, 2014 | 02:37 AM
  #85
97f150f/s's Avatar
since you removed the 4wd transfer case and front driveshaft, what did you do to the front axle assembly? Did you leave the gears in it, etc?
Old Dec 23, 2014 | 02:14 PM
  #86
F150_UAE's Avatar
Update : Everything is fixed up, took her for a run around the block to make sure everything works great, burns 1st gear with 1/4 throttle LOL. Issue is that turns out the front 4x4 spindles and Rotor hub couldnt function good with out the axle in place and for that it was not safe to move as bearings of the front hub heated up and jammed..
Need help finding Ford lightning front arms,spindles,hubs so I can drive this Hoe. any info on where I can find a good used set ?
Old Dec 23, 2014 | 03:47 PM
  #87
coobies5's Avatar
will the 2wd arms and spindles fit in place of the 4wd's?
I'd assume the upper arm mount is the same, but the lower?
Old Dec 23, 2014 | 04:13 PM
  #88
I don't think they will fit. On my lifted 2wd none of the 4wd components would even come close so I'm figuring vise/versa. The frame is completely different up front. But any thing is possible. Look there's a gt500 engine in a 97 f150 lol
Old Dec 23, 2014 | 04:30 PM
  #89
01 gt f150's Avatar
I may be wrong but as far as I know the lower control arms are the same with the exception of the steering stop on the back side of the arm. I made my own adjustable stops with 1/2 inch stainless hardware. Belltech makes nice spindles with 2 inch drop. Upper arms are the same which leaves coils and shocks. O.E. coils and belltech street performance shocks. I also used hellwig swaybars which made cornering well controlled. Depending on the amount of lowering you want a porta band can adjust the O.E. coils at whatever increment you want. Hope this helps. Good luck.
Old Dec 23, 2014 | 05:59 PM
  #90
coobies5's Avatar
the 4wd and 2wd lowers are completely different, there should absolutely not be a torsion bar keyway in a 2wd lower, but as for 2wd f150 and lightning control arms, they are interchangeable
