ring and pinion swap? need help
My 5spd with 3.55s is about 2100 at 60mph with stock 235 70 17s so probably about 1900 at 60. So 4.10s on his would be closer to stock I think.
Stock tires on your 2001 are 29". With those and 3.55's, you would be turning 2000 at 60.
To put it back to stock, you would need 4.30's, but you can't get 4.30's for the front axle.
Because of the taller and heavier tires, I think I'd go for the 4.56's. The mileage certainly isn't going to be any worse than you are getting now.
As I already posted, 4.10's with 35" tires would be 1900 at 60 and 4.56's with 35" tires would be 2100 at 60.
Ok after double checking on my way home....at 60mph in 5th gear my rpms were 1950 according to my scangauge2. And my rpm needle was also less than 2000 and if going by it alone I would have guessed 1925 to 1975rpms judging by the area it was in. So it was actually exactly in the middle of what we both said lol.
Okay - in your 2001 at 75 mph:
3.55's and 29" tires - 2500 rpm (this is stock)
3.55's and 35" tires - 2100 rpm (this is what you have now)
4.10's and 35" tires - 2400 rpm
4.56's and 35" tires - 2600 rpm
I recommend 4.56's.
I recommend 4.56's.
i appreciate all the help youve given me, when i pick my new drive shaft up tomorrow im going to see when they can get my truck in there, now im not sure what brand ring and pinion to go with......
