Body Lift
Old Jan 18, 2014 | 09:16 PM
GaryJ32's Avatar
Body Lift
I just purchased a 2002 F-150 and wanting to install a 3" body lift to put bigger tires. I have to pull a trailer quite often. Will I be able to raise my towing hitch up 3" to make it look factory or does it have to remain 3" below the bumper?
Old Jan 20, 2014 | 09:40 AM
JohnBoy88's Avatar
The hitch receiver is mounted to the frame, so if you put a body lift on the truck, the hitch will remain attached to the frame, which would then be 3" below the body.
Old Jan 21, 2014 | 03:10 AM
JMC's Avatar
JMC
25 Year Member
It doesn't look so bad with the hitch in the stock position.
Old Jan 21, 2014 | 03:20 AM
RathF150's Avatar
Only option to raise it up, is cut and weld. Something easily done by a professional welder.
