4 hi humming noise normal?
Old Nov 28, 2013 | 03:50 AM
Ford_boi's Avatar
K so I got a 97 f150 with the 4.6, the snow was comming down pretty good so I figured I'd test the 4x4 and noticed some slight humming up front while accelerating was wondering if this is normal for the f150's or not, I've driven Chevys and a lot of them seem to do it also but this is my first full size ford and was wondering if this was normal, it doesn't really sound to loud but almost sounds like I'm running an aggressive tire
Old Nov 28, 2013 | 09:46 PM
K.R.newbie's Avatar
Tires is what id say. If you have serious tires up front like mud tires,, you can get a hum,, as you stated. Might try and change out the front tires to a street kinda tire and see if it goes away,, the humming.
Old Nov 29, 2013 | 03:40 AM
Ford_boi's Avatar
I don't have mud tires up front, just some good year wrangler silent armor, I guess from what my buddy said that it was normal
Old Nov 29, 2013 | 06:58 PM
AJL4.6's Avatar
Change out the fluid in the front dif I had the same issue on my truck and it went away after I did a fluid swap
Old Nov 29, 2013 | 08:17 PM
serranot's Avatar
The humming is the transfer case. Normal.
Old Dec 3, 2013 | 09:15 PM
Ford_boi's Avatar
The only time I seem to hear it is when I'm slowing down sounds like a humming/ groaning in the front should I be worried?
Old Dec 4, 2013 | 09:25 AM
jutwan88's Avatar
Check your wheel bearings, could be bad and now that youre using your front wheels as drive wheels it will be more pronounced
Old Dec 4, 2013 | 04:35 PM
Ford_boi's Avatar
Wheel bearings are fine I have no wiggle in the wheels up there, only does it when I'm coasting, I'm assuming it's just cause the axle up front is turning but idk
Old Dec 5, 2013 | 03:38 AM
Old Dec 5, 2013 | 04:50 AM
jbrew's Avatar
I'd change the T-case fluid, that stuff can break down fairly quick IMO. I recall the first time servicing mine, - no consistency, looked like black swamp water lol. I heard what your referring to before. The rear ends can do that as well.
Just service all that with GOOD stuff.
