2003 5.4 spark plug change testimonial...
Old Sep 14, 2013 | 09:05 AM
jbrew's Avatar
Originally Posted by Roadie
Transformers, but you know that.
Damn Good Catch!
Thanx
Old Sep 17, 2013 | 01:19 AM
InDaRed2's Avatar
I replaced the plugs in mine at 119k miles and kept the original cops. I used anti-seize on the threads and torqued by calibrated arms like always to probably 20 something lbs. My truck now has 129k miles on it. My last job ended a couple weeks ago and I'm retired (69). So, soon I will check them to make sure they are still tight. I'll report the results since the standard advice is to not use anti-seize so they don't blow out.
I changed mine at 98K and used anti-seize on the threads. A month later number 8 backed out and shot out of the head. Thats when I found out you're not supposed to use anti-seize.
I got lucky and it backed out enough to not mess the threads up and a new plug threaded back in. I check them about every 5-10k miles to make sure they're still tight and havent had another loose one yet! At 120k now.
Old Sep 17, 2013 | 10:13 AM
Torque them to 28 ft/lb and they won't blow out.
