Now tackling the ac
Now tackling the ac
OK, so my AC wasn't cooling the truck. I bought the DIY stuff, followed the instructions, and turned the ac to max and voila, the cold air I wanted.
Took my truck out for a ride, after about 15mins, the ac wasn't cooling again.
Started driving home and all of a sudden the ac was back on.
10 min later, no ac.
What gives?
What gives?
Guess you didn't read the entire post...or I wasn't very good with description. .
It's still full charge, works than stop, after a bit starts to work again. Than goes off again......and so on.....
Sorry I assumed you lost the charge.
All good... well when I fix the problem
It could be the cycling\pressure switch, the compressor clutch, the compressor clutch relay, the PCM, or an electrical short/open, etc.
I'm uploading the HVAC portion of the service manual to my FTP site. Let me know when you have it so I can remove it. It's for a 1997, but the procedures should be the same.
HVAC
HVAC
HVAC
HVAC
Just realized something....When I turn the heater on or the A/C I hear the pulley spinning on and off all the time. It may come on for about 5 sec and off for about the same time. It does this continuously as long as I have selected defrost, heater, a/c. But if I have just fan on I don’t hear the noise.
Generally one line coming off the compressor will be very cool to the touch and the other quite warm. If yours feels like this, you almost certainly have a blend door issue and I have never fixed one on this truck, but it usually requires pulling the dash off. Maybe someone else will chime in on that.
Its normal for the compressor clutch to engage and disengage any time an A/C mode is selected - including defrost. 5 seconds seems a bit short though - of course I'm in 110 heat right now. If the clutch never disengaged, that's usually a good indicator of low refrigerant.
