Front rotors
Old Jun 6, 2013 | 09:37 AM
Nammy's Avatar
Front rotors
How does it come off? I have the calipers off nad I tried hitting the rotors a few times but it's is not moving. Do I need to remove the wheel bearing retainer nut? mine is a 4x4....
Old Jun 6, 2013 | 09:47 AM
Tackle's Avatar
Good ole rust. You don't need to remove the axle nut on a 4x4 as it is seperate from the hub.
Use some penetrating oil and get creative. On other vehicles I've put a bolt and nut through the back where the caliper bolts go and cranked that down to get it to pop off.
Old Jun 6, 2013 | 09:51 AM
Nammy's Avatar
Ok, thanks. Just wanted to make sure I didn't missed something. I'll have to get stronger than the rotors.
Old Jun 6, 2013 | 10:40 AM
jethat's Avatar
Break out the BFH..
Old Jun 6, 2013 | 11:54 AM
Nammy's Avatar
Originally Posted by jethat
Break out the BFH..
Old Jun 7, 2013 | 07:22 AM
tpndrcn's Avatar
Definetely just stuck from the rust, put your lug nuts on and beat the rotor face in between the studs. Then when its off clean the outer surface of the hub assembly with some sand paper and put antiseeze on it and you won't have such a problem next time!!
Old Jun 7, 2013 | 09:32 AM
There is a How To in the Articles and How To section that demonstrates this. Look in the index under brakes.
Old Jun 10, 2013 | 09:41 AM
Nammy's Avatar
Got it finished. But it wasn't without a few extra $$ for more parts
Had to change 2 of the callipers and the hand brakes has been completely changed.
