performance fix it tips and suggestions?
Old May 7, 2013 | 03:33 AM
4x4problems's Avatar
I'm trying to do everything I can small or big to help make my 98 f150 run smoother or better in any way I'm still learning a lot when it comes to the mechanics and how to fix and repair things but I know the basic things like brakes, oil changing, the common sense things of owning a vehicle. So any knowledge on what I can do to make it that much better is what I'm looking for any ideas?
Old May 7, 2013 | 04:15 AM
AndersonS's Avatar
Which engine do you have, and what's your budget?
Without knowing those two bits of information, I'm just going to assume you have the means, and recommend you do a lightning swap.
Old May 7, 2013 | 08:28 AM
4.6 v8 triton and like I said big or small if its worth it and cost a pretty penny I can come up with the budget for it. What would a lightning swap be?
Old May 7, 2013 | 10:15 AM
That would be swapping a supercharged 5.4 into it. Requires a LOT of work and $$$$.
Old May 7, 2013 | 11:24 AM
4.6heavymods98's Avatar
Lots of things you can do but if your running lean figure that out first. How do you know your running lean are you getting a code? Are you running stock right now? You have a single overhead cam and only 2 valves per cylinder so this engine is not designed to be a performance engine without lots of mods that will be spendy . I have have tons of power now with my 98 4.6 but look at my list of mods below. Once of the most noticeable and mods is when I cut my 4 stock cats off and went to two magnaflow high cats . A lot of guys here do a Gotts mod to their air intake and seam to like it I myself have a K&N short air intake but most people on here dont care for K&N but I do well with mine. Underdrive pulley was cheap and simple as well.
Old May 7, 2013 | 05:10 PM
AndersonS's Avatar
Sorry, the lightning swap was a joke answer, but it would do everything you asked.
First, make sure you've done a full tune-up, if you haven't already done so.
You can change your exhaust to long tube headers and hi flow cats in conjunction with a custom tune for a nice little power boost.
If you don't want to buy an intake, you can do the "gotts mod" to free up a little airflow as well.
If you're electrically inclined, you can install a set of e-fans to save a little fuel and reduce parasitic drag on the engine.
More involved modifications will start to push toward the $1,000 mark, so whatcha wanna do?
