No oil pressure after transmission swap?
Yea, you really can't do to much to the V10 anyway. The have that crank wrap problem lol (crank flex). Unless someone makes a better crank for them now ?
Doesn't matter, that motor would be fun enough for me. Cool swap.
Save this link, - it's from Engine Builder Mag, who is Babcox. These guys know the modulars inside and out. There's two pages on oil pump tech. Seems to me, there's plenty that can go wrong. Babcox/Engine builders info can be trusted. Read this to give you a better idea with what can happen, - if you not aware.
Engine Builder Mag (Babcox)
I know you mentioned running thick oil somewhere, - I think as a joke lol. You really shouldn't as the pump can work twice as hard because of the pickup screen restriction. It may just burn up prematurely. Not saying that's what happened, I have know idea why the pump quit or plugged. At the moment anyway. Quick google search; it's not that uncommon, -
Google Search results ("V10/OP)"
Yeah, if I have to cut that motor out, it's getting a 3V - or maybe I'll get a couple pairs of 32v 5.4 heads and weld on two more cylinders. How hard could that be?
Seriously though, I thought about the 3v but cam phasers kind of scare me. I also wonder if the cam phaser issues are just like the spitting plugs issue. Not really an issue if you do stuff right and use the right oil.
I wouldn't attempt a 3V with a 2V original power plant vehicle. I'm not sure you could get EVERYTHING to work right. I don't have that kind of ambition, -if I do, it's very well hidden. What a headache that could be lol. I guess, if you educated yourself enough on it you could do it, but 2V to 3V isn't an easy task.
Maybe you know different, - I'd have to do some studying myself.
Found this on another forum. - Power differences,-
1999 V10...275hp around 400 ft lbs torque (2-valve)
2000-2004 V-10...310 hp @4250 rpm, 425 ft/lb torque @3250 rpm (2-valve)
2005 up V-10...362 hp @4750 rpm, 457 ft/lb torque @3250 rpm (3-valve)
In 2000-2004 the 2V V10 got "PI" head or Performance improved that bumped up power quite a bit especially above 3k rpm. The heads increase flow quite a bit. Late production 02'-04' V10 got extra threads in the spark plug hole.
2005 Up V10 got an Extra Valve per cylinder (3 valves instead of 2) and a variable volume intake manifold, more "Header-like" exhaust manifolds and a freer flowing exhaust. (Without the crappy y-pipe like on the 00-04)
I'm sure some tuning was done to optimize the changes, but not too much.
Make sure you check out the OH cams/caps. Like I mentioned before, - when you get a chance of course. Were the shavings aluminum or metal ? Did you give them the magnet test ? I read up a little bit about that engine. What I got so far is the by-pass pump sticks easily, If the by-pass pump did indeed stick, it should still be stuck.
I just took a magnet to the shavings and yeah, definitely aluminum.
I'm hoping to get the valve covers off today on my lunch break (I work from home). I thought I could get the timing cover off without removing them, but they don't seem to want to come off. I need to remove them eventually anyway... IIRC there are no cam bearings, its the machined aluminum surface on the head, so I don't care what it looks like under there. I'm running it! OK, I'm kind of kidding. I'll take a peek.
Does anyone have a brand preference for rod and main bearings and if so, why?
