Does anybody have a write up or could tell me how to delete ABS?
Just because the rotors are new doesn't mean that they're not warped! Take it back to who ever did the work and have them recheck everything!! Using an impact wrench instead of a torque wrench and/or not tighten lugs in the proper order and in stages can EASILY warp a rotor. If you want to check for yourself jack up the truck so that the wheels can turn freely. Then get a dial indicator and mount it to a magnetic base and set it up to check the run out on each rotor as you turn the wheel by hand.
