help!! i want to fix up my 2002 f150
Old Mar 22, 2013 | 02:48 AM
gbyrd01's Avatar
Okay y'all, ive got a 2002 f150 super crew and its pretty much bone stock. I really want an aggressive look but on a budget. I don't need no huge lift or big mud tires(since I drive well over 50 miles a day), but still would like a aggressive off-road look. I considered a leveling kit just so it wouldn't look stock, but wouldn't know what to get. And I really love the tires that stick out a little for that real aggressive look, and more wide tires, but again, I wouldn't know way to get. I've got 265/70/r17 Firestone destinations(brand new) and the stock 17s on them. If there is anyone that could help me budget build my truck I'd preciate greatly!!!! thanks for reading!
Posted from F150online.com App for Android
Old Mar 22, 2013 | 05:44 AM
ford4life.'s Avatar
Are you 4wd or 2wd?
I would level or small lift with 33x12.50
If it's 4wd just crank the torsion bars.
2wd they have a level kit for it I think.
Old Mar 22, 2013 | 10:50 AM
pizzaman711's Avatar
Since your on a budget crank the torsions if your 4x4 like he said^. Or if your 4x2 you can go with a 2" spacer, those are the two cheapest ways your gonna lift it.
Old Mar 22, 2013 | 03:59 PM
gbyrd01's Avatar
Thanks for the replys guys.
my truck is 4x4 and I have tightened the torsion bars but I still feel like it wasn't enough. it's still a little lower in the front and would still like it a little higher. I do have a little money to spend but I can't go out and buy me a huge expensive 6" lift(as much as I want to!) I don't want to go to high because I still want to keep my brand new tires on it and they are not very big
Old Mar 22, 2013 | 04:19 PM
ford4life.'s Avatar
You can crank the t-bars all the way. Me I would go all the way than back them down a little bit to ease the ride some. Or just keep messing with them till you get it where you like. And you can all ways add a leaf or block in the rear if wanted
If wanted you can get a 4-5 inch lift for 1000. http://roughcountry.com/suspension/4...0_97-03_5.html and a 6 inch for 1300 http://zoneoffroad.com/product?ki=308&gr=-1#no_op
Just don't buy aftermarket keys.
Old Mar 22, 2013 | 05:14 PM
Or body lifts are cheap too if you can so install yourself.
Old Mar 22, 2013 | 06:30 PM
ryan.sampson's Avatar
Make sure you get an alignment after you crank those torsion bars! Or you'll be replacing those new 265's you got
Old Mar 22, 2013 | 06:50 PM
gbyrd01's Avatar
pizzaman-would a body lift level it out? and what all comes with a body lift cuz I more than likely be able to do the work myself. and ryan-i definitely need to cuz them tires ain't much but the they sure ain't cheap!
Old Mar 22, 2013 | 06:57 PM
Missed the part where you only wanted to level, just saw you talking about a 6" being too high ha.
Old Mar 22, 2013 | 07:09 PM
gbyrd01's Avatar
how much would a body lift run? and its not that it's too high, I'd love to be able to put one on there. the only reason why I can't is because of the tires being smaller, smaller tires and a big lift looks goofy to me. Id like to put a pic on here but don't know how?
Old Mar 22, 2013 | 07:31 PM
3" body lift is in the 2-250 dollar range iirc depending where you get it. It's install thats expensive, it can run you upwards of 600+, that's why it's so much cheaper if you can do it yourself.
And upload it to a site like photobucket and post the link that has the [img] tags around it.
Old Mar 23, 2013 | 06:26 AM
gbyrd01's Avatar
I think ima go 3" in the front and 1" in the rear, hopefully itll look good!
and here's a before pic Name:  2013-03-22_18-31-01_877_zps1bd29846.jpg
Old Mar 23, 2013 | 09:47 AM
4x4wolf's Avatar
Well since your torsions are already turned up, get some wider wheels and 285 or 305 tires and you'd be surprised how much different your truck will look. Good looking truck by the way, love the color.
Old Mar 23, 2013 | 05:29 PM
hunterjh's Avatar
3 inches up front and you'll self destruct you front suspension
Old Mar 23, 2013 | 07:48 PM
gbyrd01's Avatar
I'm lookin at some Goodyear Wrangler Authority 31x10.50/15 and was wonderin how they ran. and what all I'd have to do(if any thing) to my truck to get them to work. and yea I got to researching and I defently don't want my front end destroyed
