Engine swap
Old Feb 21, 2013 | 10:46 AM
Will_F-150's Avatar
Engine swap
I have a 97 4x4 standard tranny and the motor is a 4.6, I was wondering if I can drop a 5.4 in with that tranny? thanks guys
Old Feb 21, 2013 | 11:23 AM
1997 lariat 4.6's Avatar
yep, but tranny wont last long.
Old Feb 21, 2013 | 11:33 AM
JMC's Avatar
JMC
25 Year Member
Actually it is true. The transmission will not last for long.
Old Feb 21, 2013 | 09:18 PM
Will_F-150's Avatar
Why will the tranny not last long?
Old Feb 21, 2013 | 09:50 PM
MIKE 04 GT's Avatar
the 5 speed trannys are very weak from what i have read, the extra torq will kill it.
Old Feb 21, 2013 | 10:38 PM
The M5OD-R2 is a light duty transmission built by Mazda. It was not designed for a V-8. It's marginal behind a 4.6 so a 5.4 will really strain it. It has a weak input shaft.
Old Feb 22, 2013 | 10:33 AM
Will_F-150's Avatar
Is there anything I can do to strengthen the transmission, I have been talking to more people and doing research, and everyone says the same thing
Old Feb 22, 2013 | 10:45 AM
Will_F-150's Avatar
Also something you guys might know, is the t case the same as the auto trans, or different because it's manual trans?
Old Feb 22, 2013 | 05:11 PM
JMC's Avatar
JMC
25 Year Member
Should be the same one. There are however 2 different transfer cases. One is electric shift on the fly and one is manual shift on the fly.
FYI the 4.6 develops 390 ft/lbs of torque. I broke 3 M5OD with a 4.6. The 5.4 develops 350 ft/lbs. You can use a ZF transmission from a SuperDuty but it will be a very tight fit.
Old Feb 22, 2013 | 05:30 PM
Check your post for typos, JMC - the 5.4 has considerably more torque than the 4.6.
You broke 3 of them with the 4.6, now how many have you broke with the 5.4?
I believe the ZF needs a body lift and/or hacking out the tunnel to fit.
Old Feb 23, 2013 | 09:05 PM
JMC's Avatar
JMC
25 Year Member
OOPS! 290 for the 4.6. I lost count on how many with the 5.4. And yes the ZF needs massaging of the tranny tunnel or a body lift.
Old Feb 23, 2013 | 09:51 PM
Veteran: Army
perfect reason for a body lift
