abs light
Old Feb 20, 2013 | 11:38 AM
foxy510's Avatar
abs light
can i reset abs light by obd reset or...?
Old Feb 20, 2013 | 11:43 AM
dirtrider596979's Avatar
Nope, an abs scanner is required. Once the problem is fixed it should go out on its own(mine did any way). Have it scanned and see what it says. Mine had three different codes and the mechanic said just change the front left sensor and it will go out, witch it did.
If you find someone to get you the codes post them up here, ill compare them to mine.
Old Feb 20, 2013 | 12:14 PM
foxy510's Avatar
will do ..thanx
