What gauges should I use
Old Oct 25, 2012 | 11:06 PM
Water and Trans temp, still havent wired them up
https://www.f150online.com/forums/19...sh-bubble.html
Old Oct 25, 2012 | 11:44 PM
Jay87LX's Avatar
I went through the same thing and just decided to get the Edge CTS programmer
Old Oct 26, 2012 | 12:01 AM
str8t six's Avatar
they dont do any good if they aint wired up
Old Oct 26, 2012 | 04:09 AM
02FORD4X4's Avatar
I was just thinking about this Pat. If I ever add boost or just want more gauges I will be doing the bubble.
Jay I would just get the programmer but I really like the look of the gauges and I dont want the programmer to be hooked up all the time.
Old Oct 26, 2012 | 07:04 AM
Galaxy's Avatar
Woah dude....where'd you get that dash?? Details? I really like that.
Old Oct 26, 2012 | 02:13 PM
02FORD4X4's Avatar
He did it himself, look at the thread underneath the pic.
Old Oct 26, 2012 | 03:31 PM
ford4life.'s Avatar
Ummmmm...excep for oil pressure, mechanical gauges don't have fluid running to the gauge. And many guys run mechanical gauges; lines breaking isn't exactly a common problem. Electric is easier to install, yes; but the full sweep of a mechanical gauge looks soooo much better. You can get full sweep electric, but now you're getting expensive.
Yup sorry. Forgot temp sensor was on block even for aftermarket.
Old Oct 26, 2012 | 11:22 PM
02FORD4X4's Avatar
What are more of the pros v cons on mechanical gauges? Also how difficult are they to install? Ive narrowed it down to either autometer phantoms or c2s.
Old Oct 27, 2012 | 01:24 PM
yah i know, but she's not my DD any more so i dont see her but once a week....
yeah hand made
Old Oct 27, 2012 | 01:37 PM
eizzle's Avatar
Nice dash work patman, hey check it out, your surrounded by fords in that pic!
Old Oct 27, 2012 | 01:48 PM
thanks!
Old Oct 27, 2012 | 09:28 PM
Galaxy's Avatar
Pros…
-Full sweep face looks cooler!
-(used to be) more accurate reading
-cheaper (I think)
Cons…
-difficult to install (relatively speaking; compared to electric)
Old Oct 28, 2012 | 01:38 PM
MitchF150's Avatar
Mechanical has the capilary tube and sensor hooked up and you can't remove it for install. You gotta thread that big sensor head thru the dash/firewall and not kink the tube. Also, it's a fixed length and can't be lengthend or shortened, so you get what you get there.
I went with simple 90* sweep electric water and trans in a dual pod on the piller and wiring it up was simple.
I tapped into the trans output line up front, before it goes into the rad. I tapped into the hose from the engine to the heater cores inlet.
You don't get the plumbing or additional wiring with most gauges. Mine didn't at any rate... Got all that stuff at the local Home Improvement store.
I've had my gauges in for around 10 years now and they have been trouble free and tells me all I need to know.
Mitch
Old Oct 28, 2012 | 09:13 PM
msk59's Avatar
I used Glow Gauges and they have package deals on eBay and on their website. I used three: Oil Pressure; coolant temp and transmission oil temp. Looks good. For some reason cannot upload the picture.
Old Oct 28, 2012 | 09:56 PM
02FORD4X4's Avatar
Ive decided im going to use autometer phantom 2 series gauges. They look really good. All i gotta do is get the money for em together.
